12thgenusa wrote:
...MPPT simply out-performs PWM at any realistic panel temp. And even though MPPT amps decrease as battery voltage increases, it is still greater than PWM.
Your attempt to prove your point by using an extreme case falls short in real life use.
I agree.
The key concept that Salvo is missing in his attempt at proving his point is energy transfer into the battery and/or energy transfer out of the panel.
Instead he focuses on a reduction of amps as a degradation of system performance which simply is not true especially when voltage increases to keep power constant...
