ken white wrote:
red31 wrote:
ken white wrote:
The PWM Controller makes the solar panel assume the battery voltage under normal operating conditions,
What makes the panel match batt voltage without a controller, ie directly connected?
The panel has an operating space where it acts as a constant current device - its internal impedance varies linearly with supplied voltage.
An ideal constant current device can assume any voltage across it.
The panel also has an operating space where the resistance changes non-linearly with voltage, and this starts to occur at the voltage point when the panel current starts to diminish quickly for a given irradiance.
Maximum panel power occurs on the non-linear resistance part of the I-V curve and that's where the MPPT controller operates.
A battery also has an internal impedance that is dynamic and is a function of its internal charge level and the physical condition of its plates.
If we were only interested in maximum power transfer, it would occur when the controller acts as an impedance matching device and matches these two internal impedances.
x2! Ken you hit the nail on the head in clearly and consisely describing solar panel operation. They are highly non liniear devices, as are Lead Acid batteries. Optimizing performance of a solar panel a charging device for a battery is non trival.
