freetheheal's avatar
freetheheal
Solar Panel Wiring on Rubber Roof
I have a rubber roof and I need to run solar wiring from the panels to the combiner box. The length will be about 15' and I have small square plastic feet that you can stick on the roof and attach a zip tie through and then zip tie the cables to the roof. I also have the option of putting two screws through these plastic feet.
I would like to avoid drilling additional holes in the roof for all the feet and I'm wondering if I can use the tape that's provided on the feet as well as dicor to secure them to the roof. My fear is it will only be secured o the rubber membrane and will this try to pick the membrane off the roof while traveling down the interstate at high speeds? I've seen one person do it like I'm describing on a Jayco forum and no one advised against it and they never wrote back after the install saying the rubber membrane ripped....
Thoughts?
Having RV issues? Connect with others who have been in your shoes.24,351 PostsLatest Activity: Jan 19, 2026
