BFL13
Nov 28, 2020Explorer II
An Li does not charge "faster" unless the Li will accept the charger's max amps, but the ordinary battery bank of the same AH size won't. Solar is generally a low amp business, with all day to recharge.
So any so-called "faster charging with Li" is not going to be realized with solar recharging. You would need a much higher amp recharge scenario to get any of that. A pair of flooded batts at 200AH at 50% can accept 60 amps no sweat. 60 amps means a lot of solar and would probably be at 60 only around lunchtime anyway.
There can be good reasons to have Li, but the "faster charging" claim needs to be very scenario specific.
Having RV issues? Connect with others who have been in your shoes.24,401 PostsLatest Activity: Jun 10, 2023
