BFL13
Nov 28, 2020Explorer II
"Faster" means restoring the same AH in less time. Since H is shorter, A must be higher to get the same AH.
The scenario has to be where A is higher than it would be charging ordinary batteries over that shorter time period. Plus as mentioned, you have to specify the SOC range.
It can be no faster doing a 50-80, but faster doing a 50-90 due to the 80-90 being still at max amps in one but tapering amps in the other.
Amps can't be higher if the charger is current limited at its max amps over the SOC range in the scenario for the ordinary batteries just by switching to the Li. You can add amps if you have more chargers, where the ordinary batts won't accept more but the Li will.
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 15, 2026
