Itinerant1
Nov 28, 2020Explorer
pianotuna wrote:
Hi,
The point everyone is missing is that lead acid need to be charged to 100% as often as is humanly possible (without generator use).
Li has no such constraints--so a couple of days of bad weather don't matter. Of course the battery management system might leave you "hi and dry" (which is a good thing given the price) as Li hates being taken to zero volts.
The same is true of SiO2--and as I'm very much part time again--I'll go for a 600 amp-hour bank and probably never need a generator again. The two advantages of SiO2 over Li are cold and zero volts without much damage.
BFL13 is a master of recovering flooded Lead Acid batteries--but he did not have much luck with AGM.
Here is an example of this month from solar, just the beginning of my psoc use for winter. Dec, Jan & Feb the periods of psoc can extend out to 21+ days before a string of poor solar days force a 2 hour generator run give the batteries a couple hundred ah boost. 40 days was my longest of psoc use. This will be the 5th winter of this kind of use.
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 15, 2026
