Just got a 100w panel and want to run a 12v 80w radiator fan, NO BATTERY. The panel is cranking out 23v do I need to put a controller in the middle. All controllers I look at have a battery hookup b...
Will the fan be damaged by a higher voltage? If not then panel direct might power it. Panel will do 5 to 6 amps aimed at high sun mid-day mostly under 5 rest of day
Some controllers work no battery Some say they are for running lighting
Having RV issues? Connect with others who have been in your shoes.24,404 PostsLatest Activity: Aug 06, 2026
