Just got a 100w panel and want to run a 12v 80w radiator fan, NO BATTERY. The panel is cranking out 23v do I need to put a controller in the middle. All controllers I look at have a battery hookup b...
I had a solar attic fan in a previous house. Pretty large fan and pretty small panel. No battery. Accomplished exactly what you want. Ran when the sun was out, passive when no sun. Even had a thermal switch you could loop in. It was rated for like 1500 CFM. Don't see why the same method would not work with your setup.
Having RV issues? Connect with others who have been in your shoes.24,404 PostsLatest Activity: Aug 06, 2026
