ReneeG
Jul 08, 2022Explorer
Microlite Mike wrote:Skibane wrote:prstlk wrote:
Both of us have to use CPAP machines so this is not a good thing. We make sure that everything else is shut off even unplugging the coffee pot and TV.
There is a huge variation in the power consumption among various CPAP machines.
Switching to a different model might be the only change you need to make.
Biggest difference is whether one has heat/humidity options or not. If they do have "heat" then turning it off if possible will reduce power draw on most machines by over 50%
You're right. Hubby does not use the humidity option when we're camping.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 17, 2026
