prstlk's avatar
prstlk
Solar panels and lithium batteries
We are thinking of installing 2 solar panels and replacing our deep cycle batteries with lithium batteries. Big cost but if it gets us where we don't run out of power with our current set up it might be worth it.
What we have right now is a Owen 5500 generator, inverter/charger and 4 deep cycle 6v batteries, which are 5 years old and we know they are close to needing replaced.
We are boondocking and run the generator until the panel shows full but we run out of power in the middle of the night. Both of us have to use CPAP machines so this is not a good thing. We make sure that everything else is shut off even unplugging the coffee pot and TV.
Has anyone switched to the lithium batteries? Will installing just the solar panels be enough with 4 new golf cart batteries?
Any feedback would be appreciated.
  • wa8yxm wrote:
    T
    How many watts do we use per day
    This should really be figured out first.
    Also, as someone else suggested, you may not be fully charged. While hydrometer is the gold standard, turn off the generator and let the batteries rest for an hours. If they aren't up around 12.7v, you didn't fully charge them. What you likely saw was the charging voltage which tends to be up over 13v.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    The panel will show full long before a hydrometer will show full (A temperature compensated hydrometer is the only way to be 100% sure of full on flooded wet cells) you might want to test using one of those.. Resting voltage is also a good indicator but you must DISCONNECT the battery for a while before measuring. Else you see only "Surface charge" or the converter output.
    I'd recommend the hydrometer. Auto stores still have 'em in many cases.
    The major advantage of LI is that you can run 'em down near zero before they reduce voltage.. Just make sure you have the proper solar controller.
    Also you need to do a bunch of math to decide
    How many watts will the panels actually produce (Figure half their rating)
    and the loss in the charging cycle. MPPT controllers Maximum Power Point Transfer) will charge fastest .
  • Please don't tell us the four light panel is saying full and the generator is turned off. Need to get these batteries up in the 14.4 to 14.8 voltage range and hold for an hour minimum to be about 95% while camping.
    Going to need to get this right for lithium & solar anyway so dig into the inverter/charger specs and verify with a voltmeter what is going on. Post your findings.
    And yes I have solar and lithium. Huge improvement over GC2.
    Not yet, but when I do, I’ll install at least two of these 206 Ah SOK batteries.
    Remember, your charger will need to have adjustable Absorbtion and Float battery voltages.
    prstlk wrote:
    Will installing just the solar panels be enough with 4 new golf cart.
    Probably not since you are draining fully charged batteries each night.
    I’d replace your lead-acid with lithium batteries first.
  • My solar system works well with my 200 amp hour Lithium battery but the panels, battery and controller are properly sized to my usual electrical use. Start with your average daily amp use then multiple it by 1.5. Size the three from that number. Done right, you’ll be able to camp without generator noise and maintenance.
Having RV issues? Connect with others who have been in your shoes.24,298 PostsLatest Activity: Aug 10, 2025
