RoyB
Jul 29, 2015Explorer III
I like the large 1/4-20 PLASTIC KNOB Rich is using... Of course however PLASTIC and UV rays don't mix well...
I am thinking of going the ALUMINUM UNISTRUT idea going all the way across the trailer roof and securing these sections at the ends close to the side of the trailer roof where you should have something good to mount to. I am not a fan of drilling holes in the roof on my POPUP trailer.
My POPUP TRAILER may have to have a couple of these 120WATT panels mounted after the roof has been raised and locked due to the extra weight of panels. My roof is electric and already has a 13,500 BTU Air Conditioner mounted on the roof...
This is sort of my plan using the across the roof light weight Aluminum UNISTRUT sections. I can slide the mounting nut anywhere inside the unistrut section for the panels... I will use right angle mounts to the side of the solar panels.
The larger 240WATT panel I am thinking about will go across the rear of the roof side to side. This is the one that may be the best to install after the roof is raised as I can get to at least the mounting angles on both sides and the rear by standing on a short stepladder. The inside solar panel mount not easily accessible from the ground can be just a support angle not actually screwed down to the unistrut frame section.
Still in the scratch the head mode here...
Roy Ken
Roy Ken
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 12, 2026
