bpounds
Feb 27, 2019Nomad
I know everyone wants you to do complicated formulas. And even after you do that, the answer will still be different for each individual situation. Nothing wrong with doing the surveys, but you just want some point of reference to get your planning started. The geeks just love to overcomplicate stuff.
So here is my suggestion. Go with a minimum of 1 watt solar panel per 1 AH battery capacity. And figure a maximum of 2 watts solar panel per 1 AH battery capacity. Lean toward the smaller side if budget is important to you. Lean toward the larger side if you like a little overkill, and if you want a good charge on a less than good solar day.
But whatever you do, make sure you have a plan for adding more panels in the future.
400w solar is doing a great job on my 230AH battery bank, which is a pair of 6V. I could add another 200 to 400, because I planned the layout that way, but I've found that I don't need any more. At least not unless I add more batteries.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jan 17, 2025
