When I saw my first solar panel connector I gagged.
These have been atop Quicksilver since the 1980's and located about a half mile from the breakers of a tropical ocean with a stiff afternoon sea breeze.
A description of a Weather Pack Terminal. Flip the latch with one thimb and yank to disconnect.....
The female, tower Weather Pack connector housing is manufactured of nylon plastic and has silicone seals to prevent moisture and dust ingress. Weather pack connectors ensure secure connectivity as each connector has a locking mechanism that align the terminal and seal, and acts as a strain relief for the terminals. Features positive snap-locking action with secondary locking that helps terminal retention and provides access to terminals for service. Weather Pack connectors are designed for use in engine compartments and are ideal for automotive, marine, agricultural, and other harsh environment applications.
Stops in all cavities to ensure proper insertion of terminals.
All connectors indexed to prevent mis-matching.
Female (tower) housings connect with female terminals.
Housings, terminals, plugs & seals sold separately.
Rated -40°C to 125°C.
