Golden_HVAC
Mar 06, 2015Explorer
Check out this website too.
SunElec.com
You will want something with a frame on it. Then you can make roof mounts, and run UV rated #10 wire to the refrigerator vent, and on to the batteries.
If you buy a '12 volt nominal' panel, rated around 22 volts open circuit, then you can use a $25 PWM controller or MPPT, while a higher voltage panel will require a MPPT controller, and they can be much more expensive...
You can click on 'view posts' under my name, and search within that 'solar' for a complete description on how to install a solar system.
Good luck,
Fred.
SunElec.com
Good luck,
Fred.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
