kab449
Mar 29, 2019Explorer
Solar Panels
I want to add another 100 watt flexible panel to my RV. The one I have now is a Go Power Flex-100. Go Power Flex-100 Question is: Would this panel work at a significant cost savings? AllPOWER...
azrving wrote:
I about choked on the first link. They should be fine together. I didn't see the voltage on the first panel but it's probably close to the other one.
What controller are you using as it matters with how you wire the panels.
