MEXICOWANDERER
Nov 10, 2016Explorer
Examine the plug in brick carefully. By law the brick must display the power voltage range admitted from the AC plug in inlet to the brick (this cord is usually disconnectable just like a laptop power brick cord)
And then the brick's info with continue on and then list the output voltage and amperage potential of the brick. Aha! This is what you are after. Write down the voltage (12 volts)? and write down the amperage (5 amps)?
Does the brick say 12 volts and 5 amps (very common)?
If yes, you can purchase a power cord that plugs into a cigarette lighter socket, then purchase a long extension (I have encountered ads for 12 feet) cigarette light plus an socket extension cords.
This is a far more practical way than using a PURE SINE WAVE inverter that wastes power converting 10 volts to 120 volts AC then back to 12 volts. The power waste going to inverter is expensive and is sort of nuts...if tour CPAP is indeed 12 volts.
But with a battery conversion the CPAP must be unplugged from the cigarette lighter before starting the engine.
Having RV issues? Connect with others who have been in your shoes.24,376 PostsLatest Activity: Apr 09, 2026
