Sam_Spade
Nov 10, 2016Explorer
TxGregory wrote:
But I don't want to spend that kind of money if I can avoid it.
Not sure about the cost of this but I think you would be better off in the long run to get CPAP machines that run directly off 12 V and then just increase your battery capacity if needed.
Or check the wattage of your present machines and get a small inverter to power just IT from an existing 12 V outlet.
Feeding an inverter into the whole RV is probably not a good idea; too easy to overload it.
Having RV issues? Connect with others who have been in your shoes.24,376 PostsLatest Activity: Apr 09, 2026
