ktmrfs
Nov 10, 2016Explorer III
first thing I'd do, and I do use a cpap is double and tripple check that it is NOT 12v compatible. virtually ALL the recent cpap machines will run off either 12V or 24V DC. 12V dc is a simple solution, plug it into a cig lighter adapter. 24 V is also very very simple, battery power solutions as well as the mfg of most of the 24 V machines make a 12V to 24 V DC to DC converter.
Turn off the humidifier and you can run a cpap for easily 4-5 nights off a good battery.
Or lithium ion rechargeable battery packs are available as well that will run the cpap for at least one night without the humidifier.
that solves the cpap problem.
Next, most every laptop can be run off 12V as well, no need for an inverter. check on amazon or the mfg of the laptop and you will likely find a 12V power source available.
Having RV issues? Connect with others who have been in your shoes.24,376 PostsLatest Activity: Apr 09, 2026
