BFL13
Nov 11, 2016Explorer II
MrWizard wrote:
its simple look at the charge voltage for your AGM 14.6 > 14.8v
that is the voltage needed for full charge 13.6 > 13.8 is the float voltage not the charging voltage
Well it ought to be simple, but I would still be worried with AGMs in the solar situation previously mentioned where it works ok with Wets like I have. Just add water if you happen to overdo it.
--I only have the one AGM in the TC and I will recharge it with my Vector charger at 14.6 until it says "FUL" and then I will Float it at 13.7 with my 7445 converter.
Everyone else with an AGM is on his own! :)
Having RV issues? Connect with others who have been in your shoes.24,375 PostsLatest Activity: Apr 09, 2026
