Almot
Jun 30, 2016Explorer III
Whaler wrote:
PI have solar power feeding to rocker switches by the entry door but cannot find any solar power on any wire in the battery compartment. Is this normal? Could it power through the Freedom inverter?
Check the voltage on the inverter then. With batteries removed and shore power off. If you find the same 17V there, then this is what you have.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
