swimmer_spe
Oct 28, 2022Explorer
Solar power
My 2023 Cherokee Wolf Pup 22RR has a factory installed solar panel. Realistically speaking, can the trailer be used with the single battery installed without it dying? I am thinking of installing a...
valhalla360 wrote:swimmer_spe wrote:
It was close to freezing.
I do not know how often it was on, but when on, it was only for a few minutes.
Fridge was off.
No other power draws. Lights were off.
My hope was that the existing solar panel could allow me to last 1 week in these weather conditions. Since i can't, I will be bringing a generator and running it for a few hours to recharge and have extra batteries to parallel or swap in/out.
How often/long it's on is what counts. Down into the 30's, ours doesn't run much.
Realistically boondocking, you will have the fridge, lights and other draws to add into the mix. Best to do an energy audit and estimate everything (what is the wattage and what percent of the time is it running to calculate total w-hr), then work from there.
For a day or two of boondocking, you can cheat and let the battery run down with the idea of plugging in at the next campground or when you get home to fully top it up.
For longer time periods, you basically, need to plan on replacing what you consume each day (or at least close to it). While you need at least 2 batteries (maybe more with a realistic energy audit), your big issue is sufficient charging. It's borderline running the fridge in cool conditions (when the compressor on-time is low) but once you add in the furnace, lights and other uses, not even close.
Best to parallel rather than swap batteries if at all possible due to the Peukert Effect. The basic idea is the larger the wattage draw relative to the total watt-hours of a batter bank that you draw, the fewer watt-hours you can pull from the battery bank without depleting it.
Example: Let's say you have 2 - 1200w-hr (rating) batteries (aka: 100amp-hr) and are drawing 240w
- If you parallel them, you have 240w out of 2400w-hr which is about 10%.
- If you swap them, you have 240w out of 1200w-hr which is around 20%, then you swap and are still at 22%.
Even though the ratings are the same, you might get 2600w-hr at 11% vs 2200w-hr at 22% once you are done (you would have to get the manufacturers specs for specific impacts but the principal holds)
