pianotuna
Apr 03, 2016Nomad III
Hi,
Absorption fridges are not too efficient. Mine, which is a small Dometic, uses 5.7 KWH per day on the 120 volt setting.
Given 5 "good" solar hours per day about 1140 watts of solar would be needed--plus a quite large battery bank to run it when the sun is not shining.
The drawing board starts with an energy audit.
KE6IRJ wrote:
As for power draw, I would like the power to run the fridge on power, but will probably turn it to gas regularly.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
