CJW8
Apr 03, 2016Explorer
Well, I am going to go against the grain here and recommend MPPT Because:
1. Will only add 100 to 150 dollars to the system.
2. Typically has more features.
3. Allows for 24 volt nominal verses 12 volt nominal panels. Typically 24 volt panels are less expensive.
4. Gives more charge, granted it isn't much more.
I'd also run larger than #10 wire from panels to controller.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
