red31
Apr 05, 2016Explorer
KE6IRJ wrote:
In order to give an accurate use on the remote display, the trailer power has to go through the perry's on the right, marked by a light bulb, right?
take a look at the brochure, page 2
load amp-hours is not available for that controller
http://support.morningstarcorp.com/wp-content/uploads/2014/07/RemoteMeterENG1.pdf
my non MS controller displays discharge KWH only if the load terminals are used. Typical tt user does not use the load terminals since loads can be more than the controller's rating.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
