Almot
Apr 05, 2016Explorer III
pianotuna wrote:
Yes, it is a quality controller. It is intended for two battery banks, so it might be cheaper to have the plain jane sunsaver. Having the battery temperature sensor is a "must do".
I'm not sure it has adjustable voltage set points.
Ss Duo is 25A, single-bank SS is 20A max if I'm not mistaken. Setpoints on Duo can be custom-set, though this requires a laptop AND optional meter-bus adapter. Remote temp sensor is also optional - yes, very desirable to have. Remote display is extra. And all you'll get is 25A, i.e. 2*160W or 2*180W max.
With 2 panels I would think about Bogart Trimetric combo SC 2030 - TM 2030. 30A, ~$300 with everything adjustable including automatic Absorption adjustment and complete battery monitor.
Or - Xantrex/Trace 35A and 3*160W panels. Heck, my 490W fills AGM bank to ~93-95% before noon when it exits Absorption, and then it floats until sunset. As long as it doesn't rain. Don't need no battery monitor, muchas gracias.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
