KE6IRJ's avatar
KE6IRJ
Solar Questions, yes more solar questions
Okay, before you say it, I did search, and have been reading on this for days.
Here is my question.
I have a bonus coming possibly and am trying to decide if I want to use it for solar on our trailer. I intend to use the trailer mainly off the grid, and have fall hunting trip coming up for 7 days.
Currently, I have 2 GC2 batteries, plan to go to LED lights, and a propane heater other than the trailer heat.
So, in reading, I know I want an MPPT controller, remote monitor head, and probably 200-250 watts to keep my batteries charged for the week trip.
Is it better to shop around and piece together a system or stay with something put together by someone who knows?
I was thinking this one, because they are local to me and I have seen them in action on our last trip.
http://www.solar-electric.com/solar-panels-mounts-kits-accessories/prsy/rvandsmbasoc/rv-solar-kit-280-watts-mppt.html
I don't think I need an inverter right away, since I don't use other devices when camping right now. Do I need replace my built in power converter or is this all additional?
So, am I on the right track? Are there companies or brands to avoid? Better prices I have not found? Fill me in, what am I missing?
  • What are you running off battery other than lights? And yeah you don't need an MPPT, not going to make enough diff to justify the price...Look at Renogy.com. No you won't overcharge. And that kit....? More than double, maybe triple what you should pay. Shouldn't need a new converter.
  • http://www.solar-electric.com/solar-panels-mounts-kits-accessories/prsy/rvandsmbasoc/rv-solar-kit-280-watts-mppt.html
    Kit seems like a lot of $$. PWM is fine with 12v (nominal) panels and will not overcharge.
    I would tend to buy separate components as you may not need what is provided. Such as the 30' cable might be short. Those breakers are probably not needed or substitute low cost fuse. Combiner box not needed, use MC4 parallel connectors. Mounting brackets can be made with aluminum stock from Lowes etc.
    Most important is to match the panels to the controller and fitment of the panels on the roof. Then buy wire and hardware provisions as needed. Since they are local you can run back and get what is needed or substitute other suppliers.
    If you go MPPT I recommend a large 24v panel of about 250+ watts.
  • Is there a chance of overcharging if the controller is PWT?
    That many watts? I need to measure my roof again.
  • I would not go MPPT for such a tiny system.
    It is often, but not always, cheaper to "roll your own" system.
    I would spend the money saved on the MPPT controller for more panels. 400 to 600 watts is the range I'd be planning on.
    The kit you referenced is extremely overpriced.
    What matters is having a temperature sensor on the battery bank (especially important for cold weather) and adjustable voltage set points.
    I would always allow room for growth on a charge controller--because many of us add more wattage later on.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
