wbwood's avatar
wbwood
Solar Questions
Just switched out our batteries (mismatched group 27's) with a pair of Duracell (Deka) group 31's (matched). I have a Renogy 100 watt solar suitcase. I understand that it won't be enough alone to charge the batteries. I would like to add something else that can be portable to boost the solar charging. I don't want to permanently add anything to the roof right now. We don't do extensive dry camping. We will be going to the outer banks for a week next month and staying at a NP campground. We do have the onboard generator and can run it when we can to charge the batteries if needed and let the suitcase work during the rest of the time.
Can I get another solar panel from Renogy (100 watt) and new charge controller (20 or 30amp), disconnect the old charge controller (10amp) on the suitcase and run the suitcase panels (2x50watt) and 100watt panel to the new charge controller and then to the batteries using the alligator clips? Will 200watts be sufficient for the 2 group 31 batteries (105ah each)? I would ask about two different suitcases, but a single 100watt solar panel is half the price of the suitcase and the charge controller would not be enough I would imagine for two 100watt panels.
Also another question. I've seen The Wynns use a solar suitcase and they just connected to a more permanent connector underneath their RV, instead of using the alligator clips. Anyone know what and where I can get these?
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
