mike-s
Sep 04, 2017Explorer II
Starting battery, coach battery, chassis battery. Two of these things are not like the other.
I'm only guessing that the starting battery and the chassis battery are one and the same.
But, you say that charging the starting battery only charges when the coach battery has reached "acceptance" mode. Again, I'm only guessing that you mean absorption, which would be around 80%, so the starting battery doesn't get much charge.
If you want both to charge, perhaps add one of the cheap PWM controllers, put one panel through that to the starting battery, and leave the other 2 panels connected to the BlueSky.
Having RV issues? Connect with others who have been in your shoes.24,396 PostsLatest Activity: Jun 24, 2026
