pianotuna
Feb 20, 2017Nomad III
The Honda may only power a 600 watt converter, if the battery bank is hungry. You may need to consider a battery charger depending on the OEM converter's size.
I would double the numbers to around 300 amp-hours and 400 watts of solar.
For my further thoughts on batteries and things solar surf here: https://freecampsites.net/adding-solar/
CptSydor wrote:
I have a 1000W Honda generator if needed to run a couple hours per day if needed.
From what I've figured out, I should be designing my battery system to be in the 150-200 amp hr rage with panels in 150-200w.
Does that seem reasonable for what I've described?
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 23, 2026
