Joel_T
Feb 20, 2017Explorer
I've got the same WFCO8955 charger/converter. No good. You could probably leave it charging all day and your batts wouldn't get anywhere near full. I'd hipshot you're needing/using around 40amps daily. A couple of 6v rated at 240+amps will get you 3 days or so with no solar or charging. You can bet on needing some charging time but I doubt the 1000w genny will push a big enough charger to get what you need done. I just bought a voltage adjustable single stage / 3 stage 70amp charger I've wired in close to the battery I'm hoping will give a much quicker 50 to 85+-% charge time. The proof's in the pudding they say so I'll soon (?) do a test similar to BFL13s to see how well the thing works.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 23, 2026
