pianotuna
Feb 20, 2017Nomad III
Hi BFL13,
It works for me--but it is the reason I suggested a larger battery bank and significantly larger solar wattage.
The WFCO has to go.
The WFCO has to go.
BFL13 wrote:
PT, under trees where solar doesn't work, doubling the solar won't help.
Doubling the gen would help as you say. OP can get a second 1000 and parallel them to run a bigger amp charger/converter. If his rig has a 55 amp converter that can do 14.x, that single 1000w gen won't run it.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 23, 2026
