SoundGuy
Feb 20, 2017Explorer
CptSydor wrote:
Seems like I'm not that far off with my solar estimates and it's possible in similar conditions. Though I think I need to figure out a more efficient generator back-up.
Solar aside, that can easily turn into a costly project as efficient genset charging is going to mean a larger genset, appropriate batteries to charge, a converter and/or charger suitable for charging the batteries you select, and heavy enough cabling so that charging system doesn't suffer excessive voltage loss. All of these issues are interrelated so if you don't address one and throw all your $$$ at another you could easily be not much further ahead than you are now. If you're looking for edumaction on the subject and have the patience to forge through it here's a recent rv.net discussion on the subject.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 23, 2026
