SoundGuy
Feb 21, 2017Explorer
Joel_T wrote:
But that 1000w genny at 8amps won't power much of a charger will it?
Almot wrote:
8 amps is the generator output @110V AC before the converter. This becomes 60A DC after the converter.
Not really ... Honda specs their EU1000i for 900 watts continuous (7.5 amps). In theory this should accommodate a 60 amp converter / charger running full tilt - 60 amps x 14.4 volt bulk charge = 864 watts, which one might think would work. However, this is based on calculating watts and doesn't take into account the rather poor power factor of many converters that could be as bad as .6, in which case that 864 watts stated as VA (Volt Amps) would be well beyond the capability of an EU1000i ... ergo the rationale for instead using an EU2000i. ;)
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 22, 2026
