SoundGuy
Feb 21, 2017Explorer
SoundGuy wrote:
.. there's not much point in upgrading from your current WFCO 8955 converter if you're not also going to upgrade from your current 1K genset which will be limited in it's ability to properly power that higher rated converter / charger.
Almot wrote:
Then don't get that higher rated PD70. Get PD55. Will still work better than existing WFCO, both on generator and on shore power. At a fraction of cost of upgrading the generator.
Clarity would be helpful when you post :R ... no idea what you mean by "PD70" or "PD55" but for the latter I'll guess that you referring to a PD4655 Upgrade for the OP's WFCO converter since Progressive Dynamics doesn't offer a 55 amp version in any other current series. At 950 watts input power it's still beyond the capability of an EU1000i and existing wiring the OP has in this trailer, likely 6 gauge, won't help the situation.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 22, 2026
