Katdaddy
Sep 29, 2020Explorer II
Solar suitcase problem
I bought a 130w solar suitcase a couple months back. I comes with a cheap CMTD A2410 controller. I've hooked it up only three times. The first two times all was well. Today I hooked it up to my boat batteries and it has gone haywire. I was going to check the on and off parameters to make sure they were where I wanted. The readings for the parameters are way to high, reading 29 - 30 volts. Cannot set below 29 and the display still has a readout after I disconnect the batteries. I'm assuming this controller is toast. My problem is that we are leaving on trip that I bought this thing for in less than two weeks.
Can I reset this thing or do I need to buy a new controller? If I need to buy recommendations please.
As always, thanks for your help.
