Mike3's avatar
Mike3
Solar System Advice/Feedback for new Truck Camper
I'm looking for a solar system to use for battery charging, light a/c use such as charging ipad/phones, a couple hours of TV daily and a cpac machine. No microwave or a/c. This will be used in conjunction with two Trojan 6 volt 106s.
This system was recommended by a local firm:
Aims 1000 watt Pure sine wave inverter/charger. $675
C35 Xantrex controller with LCD display and breakers. $275
Three 100 watt panels with roof mounting. $210 each
Labor to install. $420
A grand total of $2070.
I can buy the Aims inverter/charger for a couple of hundred bucks cheaper on line but I don't have the skills to install. The guys seem very professional and have a good reputation in the area. They assure me they can install it so it looks like it came from the factory.
Does this sound like a good system at a fair price for my needs.
  • Hi,
    Quality panels are under $1.00 per watt.
    The Aims is a bottom of the barrel inverter with no ability to be repaired post warranty. Xantrex makes a model that is better with larger capacity for $355.00
    I think you mean a Xantrex charge controller. It is not MPPT and could be replaced by an Ecoworthy for $30.00.
    I think you should find a different firm.
