So I would like to keep my battery charged while in storage with a solar system. Doing some searches here I can't tell if I need a $15 Harbor Freight unit or 160 watt unit. Cabelas has panels of 5, 10...
IF....it has an appropriate controller, a 15 watt panel would be barely adequate for one battery.
In my opinion, if you are going to do this you should avoid Harbor Freight and get a "name brand" unit with controller in the 100 watt range or a bit larger. That will have enough capacity to do some real charging in addition to just float maintenance.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
