OregonTRX4
Feb 16, 2014Explorer
Solar voltage help...
I just connected my solar kit (160w cmp12 controller)and the voltage while connected to the rv batteries reads 16.55v. Is this normal or too high? Sorry but im new to this.
NinerBikes wrote:BFL13 wrote:
Niner,
..." My unit at 120 watts is 3/4 the output that his is. I have seen, at most, 6.62 amps out of mine,on the charge/load side, measured by one of those RC battery charge meters with 4 readings on the screen."
When I had a 120w panel, its Isc was 7.6a and sure enough that's what I got at the batteries as seen on the Trimetric. You need to aim the panel at a high enough sun, disconnect the controller, and take the Voc and Isc on the panel's wires using a multimeter. It is under 10a so that will not fry the meter in amps setting.
You then hook it all back up and see what the amps is at the battery. If not close to the Isc you got, you have wiring issues
Your panels are poly crystalline, the OP's are mono crystalline. They are not as efficient.
my panel
Readings at 34.0 N in Late Oct 2013.
Seems I got 6.84 Amps/hr at peak, sometime during the charging regime, if only briefly with these pulse chargers. Isc is rated at 6.98, on the back of the panels. Perhaps I lost some being the sun was so low that late in the year.
5 feet from controller to battery of 12 gauge wire, rated at 20 amps, at under 7 amps, is not a loss issue. I kept everything as short as possible during these beginning trials, to minimize losses.
BFL13 wrote:
Niner,
OregonTRX4 wrote:Tom_M wrote:With everything connected it starts at 13.93 and ramps up to to 16.xx before I disconnect the solar from the batteries. Batteries measure 12.6 shortly after panels are removed. It is doing this on multiple batteries. The input to the controller and output to the batteries measure about the same at 21.xxV at the controller. So is it most likely the controller is bad? I tried connecting batteries to controller then controller to solar and it made no difference. This is what I have http://www.solarblvd.com/Solar-Panels-&-Systems-12-Volt-Solar-Panels/c1_269/p2754/W-Solar-160-Watt-Foldable-12-Volt-Solar-Panel/product_info.htmlOregonTRX4 wrote:What is "It"? Was the voltage measured at the battery when everything was connected? It would be impossible for the battery to measure 16.55 if it is disconnected and very unlikely even when connected unless the battery is bad.
Measured at batteries. It is disconnected.
BFL13 wrote:NinerBikes wrote:
10 amps is plenty with that 160 watt set of panels. It starts out at 22V and gets down to 18V in the specs, and is capable of putting out 8.88 amps,max, if the battery will even allow that kind of charge take......
Niner the Isc on that is 9.46a which he should get with the panels pointed at a high sun. You are using the Imp figure which is meaningless with PWM.
10 amps on two 6s is 5 amps per battery, which is the acceptance rate for about 90% SOC at 14.5v. So there should be no trouble finding time from 50-90 SOC for the battery bank to accept the 9.46a
Also after 90% and amps taper, you can run things that take from the solar--any amps over what the battery is taking up to what the panel can do at the time.
Eg, good time to recharge/use the laptop late afternoon while the panel can still do 9a when pointed, batts taking 3 amps, inverter with laptop load taking 6 amps
Please take a picture of the wiring you are using at the back end of the panel, where the solar controller is located, and post it up here.
As requested.
