pianotuna
Jun 23, 2013Nomad III
Hi Almot,
The collector holds only 2.7 ounces (by weight) of water. It is 24" X 25.25" X 2.125". Total panel weight is 10.6 lbs. Collector temperature is 203 F (maximum??).
Almot wrote:
And again, these 6 gallons on the roof... You can't leave it there, you have to drain it every time when you move. 50 pounds of water sloshing back and forth when you drive - no, thanks.
Also, how big is this thing?
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 11, 2026
