time2roll
Sep 19, 2016Nomad
100 watts will reduce the generator time and extend the life of the battery. Make your coffee with the honda and let it run a bit to get 85%+ charged. Then the solar would finish the long absorption charge the rest of the day and provide power for the inverter as needed. This should allow you to head into the evening with a higher charge on the battery. In time you may find you need less generator time.
When not camping the solar will do an excellent job of keeping the battery in tip top shape. I think the minimal daily cycling actually helps for storage vs a continuous float.
Go LED lights if you have not already.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: Nov 08, 2021
