westend
Sep 06, 2015Explorer
Good work!
Two items noted that you may want to address in the future: Shrink wrap on your cable terminations helps prevent oxidized wires. It looks like your junction box has a standard "pull-through" box entry. Waterproof box entry fittings are available or fill the holes around the cables with sealant. Your 3M sealant would work well there but will make retro work difficult.
Looks like you have every other thing well organized. Good luck finishing up the install!
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jun 28, 2026
