CJW8
Sep 07, 2015Explorer
Good find on the welding cable and you won't be sorry you went with the larger size. I couldn't find if you said if you are using PWM or MPPT but if you are using PWM controller, and you later decide to upgrade to MPPT, you'll be glad you used the larger wire.
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jun 28, 2026
