Rbertalotto
Sep 07, 2015Explorer
Today I finished the solar install....
Had to build a battery box to hold two Group 31 batteries and a little extra room for a future circuit breaker (on order).
The box was made out of simple birch plywood and coated with two coats of truck bed liner. At some point I'll replace it with a diamond plate aluminum version. Just didn't have time and $$ to do it now.
Had to make a little "Side Car" to fit everything as the batteries took all the distance between the hitch frame.
The top is removable and secured with a couple of padlocks
Vents supply fresh air and let it breath.
Lots of cutting, crimping and heat shrinking! I think it came out nice!
Hooked it all up, threw the battery disconnect switch and everything worked perfectly! It was 3:30PM when I threw the switch and the Trimetric was showing the batteries were receiving a charge. Batteries were at 12.85V (new batteries, never installed) and after an hour they were at 13.1V...Nice!
Can't wait to give it a real shakedown next weekend!
Lots more on my website
www.rvbprecision.comwww.rvbprecision.com
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jun 28, 2026
