Rbertalotto
Sep 07, 2015Explorer
Why do you have 2 + and only 1 -
This system used a Bogart Trimetic monitor. This is how it is wired. The house load negative (-) and all other negativeness go to a shunt mounted in the trailer. Therefore only one negative wire to the batteries. At the shunt, the negative from the solar controller and the house negative on one side and the other side of the shunt goes to the negative of the battery pack.
The 3 positives are from the solar controller and from the house positive and from the second battery.
With every negative going through the shunt, the Trimetric can "READ" all current going into and out of the battery bank.
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jun 28, 2026
