addisonl
Aug 22, 2016Explorer
You could maybe use a junction box. I set mine up where I put the whole connection/junction of wires in one spot. Inside a nice closed plastic box with weather sealed screws on the lid. Cut the bottom of the box out over the spot where I my single drilled hold goes down into the RV, into a inside wall opening where I ran all the wires. Then caulked and sealed around the box on roof really good. Almost 10 years now and never a problem or a leak. Then just unscrew the top of the box if you need access to the perfectly normal and clear connections inside.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: Apr 10, 2025
