StirCrazy
Jun 18, 2024Moderator
yhere should be a shunt on the positive of your battery only the negitive, if you want to account for the power you put back into your battery wire the positive to the positive post of the battery then on the negitive side it shoudl go battery negitive post to shunt, then everything else shoudl be hooked to the other side of the shunt. anything that doesnt go through the shunt will not be recorded as power in or out.
