Almot wrote:
MikeJinCO wrote:
Very simply. From the batteries to a disconnect switch then routes to a buss bar. That splits to :
1. Converter
2. Solar
3. 400w inverter
4. Elec Jacks-Bigfoot treated them as an option
So basically everything is in parallel.
2. Solar controller output should have it's own breaker or off-switch between controller and bus.
3. (Maybe) connect inverter directly to battery if this results in a shorter DC wire run. Also, make sure the output is not in parallel to converter input.
Hey Almot, welcome back to the zoo. :) Why? The inverter and converter should be in in parallel to the batts and can share the same pair of wires.
