MiRV's avatar
MiRV
Solar with RV Converter/Charger -- Can this be done???
Not sure if this has ever been covered in the Forum, but I couldn't find a similar thread, so am asking…
I'm looking at installing a portable (to start) solar solutions with about 200W on the RV and would like to know if I can setup the solar to connect to the converter/charger installed in the RV.
I upgraded my Magnetek 6345 last summer when the system had some issues. The NEW 6345 uses a 3 stage charger (much like those in a Solar Controller). Therefore, to save money on the initial configuration, I'd like to wire the solar panels into the converter/charger to charge the batteries vs running the generator.
Additionally, I'd like to add an inverter (2000) so that I can run other AC appliances…but I'm not sure on the charging/configuration for this.
Is this possible to use the converter/charger and then install an larger inverter for the DC to AC? And if so, how do you do it?
Thanks
