pnichols
Aug 11, 2018Explorer II
theoldwizard1 wrote:
I still say, all of the small generator manufacturers are missing the "sweet spot". 2800-3000W peak, 2400-2500W continuous. The few that are out there are too large, maybe because they need a larger gas tank.
This portable is almost in the sweet spot, if you can tolerate it's weight: https://www.yamahamotorsports.com/generator/models/ef2400ishc
IMHO, the ultimate portable generator sweet spot is a couple of Honda EU2000i gennys in parallel - plenty of power, reasonable weight per lift, quiet when not having to run full bore, and providing partial 120V AC backup if one of the two should fail when drycamping. You just have to be able to afford this real sweet spot.
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: Jun 05, 2026
