marcsbigfoot20b
Aug 13, 2018Explorer
3 tons wrote:marcsbigfoot20b27 wrote:
Well it’s not the normal 112 degrees like usual (I wanted to test at 115+) but only 102 today. The 13.5 Brisk Air fired right up on Eco mode never even reving up past 1/2 throttle.
102 degrees and 1430 ft puts the DA right at 4900 ft.
In 2 weeks I’ll try at 7500 ft and 80 degrees when I’m boondocking.
The 2000 would barely (105 volts) run the microwave by itself up there, I’m sure the 2200 will kill that.
Well looking up the specs I’d say thats outstanding Sir!
(Not sure if this is the same unit, but is 13.5k btu)
Technical Data
Dometic Duo Therm Brisk 2 Air Specifications:
Capacity in BTU/hr: 13,500
Fan motor-rated load in amps: 2.7
Electrical rating: 115/1/60 (Volts/Phase/Hz.)
Minimum wire size: 12 AWG copper up to 24 ft.
Compressor-rated load in amps: 12.4
Blower speeds: 3
SCFM, high speed maximum/minimum: 300/350
Installed weight in lbs.: 72
Minimum generator size for 1 unit: 3.5kW
Easy installation and maintenance
2 Year Protection Plus Warranty
Features of B57915 13,500 Dometic AC
Nominal Capacity, BTU/hr: 13,500
Compressor-rated load amps: 12.4
Fan motor-rated load amps: 2.7
Blower speeds: 3
SCFM, high speed max/min: 300/350
Installed Weight, pounds**: 72
Minimum Generator Size:
1 Dometic Air Conditioner 3.5k Watts
2 Dometic Air Conditioners 5.0k Watts
3 tons
I don’t see locked rotor amps listed anywhere for that Brisk 2
My 1999-2000 Brisk is rated at LRA of 59 amps.
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: Jun 05, 2026
